Repair guides and support for desktop computers produced by Asus including towers and all-in-one display PCs.
144 Questions View all
How to fix Monitor no signal/going to sleep
My pc suddenly went to no signal
But the fans spinning
Mouse and keyboard have lights
I check all the cables
And cleaning/reseating ram
I've also change my cmos batt
And try my monitor on another desktop
It's working on another desktop
8gb ddr3
asus f1a55-m lk r2.0 mobo
Add a comment
1 Answer
Chosen Solution
Hi @te47
Is there a GPU card installed in the PC (if so what is the make and model number of the GPU?) or are you using the CPU's integrated graphics (what is the make and model number of the CPU)?
Try getting into the BIOS menus and check if you get a display. Turn off the PC if it is on, then restart the PC and press the Delete (Del) key a few times immediately after it turns on and check.
If still no display, try connecting a system speaker (supplier example only) to the motherboard's speaker header pins (see Item #9 p.1-7 and p.1-22 of the user manual for location and connection details) and check if there are any beep error codes when the PC is first started.
Score 2
2 Comments:
I don't have gpu and using AMD a4-3300 w/ ati radeon hd6410
I can't get into bios it say "monitor going to sleep"
by
@te47
It appears as though the PC is not passing POST - Power On Self Test, to start booting into Windows.
Connect a system speaker as described above and check for any beep error codes on startup.
It's the best way to find out what's happening
by
Add a comment
Add your answer
Joka will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 8
All Time: 277
