The Pontiac Grand Am is a mid-size size (and later compact) car produced by Pontiac. The 1999-2005 generation is the final generation of the Pontiac Grand Am.
150 Questions View all
I have a 2005 pontiac grand am se security light on constantly and no
I have a 2005 pontiac grand am and the security light is on but not blinking. If I turn the key the dashlights, windows,lights, and the cd portion of the deck works. Also, The car will go out of park without the key in. The door fob wont work at all anymore. I have tried the bypasses but none of them work. The mechanic says the code is saying that the ignition is not communicating with the starter. I have changed the battery. The fuse to the ignition, ignition and the switch ( parts from Autozone) and the starter relay, the car will start for a second if I engage it using a screwdriver and pull on the gas but only for a second. I called a locksmith that was supposed to be able to reset the security but was stumped because the turning the key on and off method for 10min and 15 secs 3 times didn't work. Can anyone please help me with any direction of where to start.
Add a comment
1 Answer
If you used a screwdriver to turn the lock cylinder/ignition switch, irreparable damage may have occurred to the lock cylnder (where the ignition key fits into) as the lock cylinder has a magnet that passes under GMS Passlock sensor as part of the antitheft system. This problem may be complicated insofar as restoring/repairing security or bypassing it entirely (provided it can be done with a damaged sensor. Here's background info for you or someone familiar with GM security systems; https://www.tradecraftspecialties.com/Pa...
Add a comment
Add your answer
Vernice D. Arnold will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 49
All Time: 367
