Model No. A1367 / 8, 16, 32, or 64 GB capacity
915 Questions View all
Broken ribbon cable during screen replacement.
I was trying to to replace my ipod touch 4g screen because it was cracked. During the process of lifting the logic board one of the ribbon cable tore. Can someone please identify it and tell me if it can be fixed. Idk if it has anything to do with the screen because the screen also wouldn't turn on. thank you. pic uploaded in link.
http://i44.tinypic.com/2wc1t79.jpg
Add a comment
Most Helpful Answer
Thats the power/volume controls did your computer pick up your ipod when you plug it in?
Score 1
Add a comment
If it's not getting power, it probably won't turn on. You can replace the cable iPod touch (4th Gen) Volume/Power Cable
iPod touch (4th Gen) Volume/Power Cable Image
Product
$14.99
1 Comment:
the computer does pick the ipod up, but the screen won't turn on. or sometimes just for a second.
by
Add a comment
Im having the same problem i to have just ripped the cable grrr
Add a comment
If the ribbon cable from the screen to the connector is pinched, you may get a white screen that cannot be fixed because the traces on the ribbon cable have been damaged.
1 Comment:
Do you mean that you can't fix it by getting a new ribbon cable? I am getting white screen after water damage (nano 4th); occasionally I will get half stripey screen that I can use, but most of the time it is white.
by
Add a comment
yea I ripped my ribbon cable too I should've de-soldered it from the board before replacing the battery and screen. now i've gotta order a new ribbon cable for the vol/pwr, grrr...
2 Comments:
so have you now got it ,i too was trying to repair my ipod by watching a video but the ribbons got damaged....pls reply me to my email id:ramancuvic@gmail.com...i want to know from where i can get those ribbons
by
You can order a new set of the ribbon cables on here just look for the vol/pwr replacement.iPod touch (4th Gen) Volume/Power Cable
by
Add a comment
OK my thing happened too. The topcable ripped... Somi justntore the rest of it off. If I buy Anne's on how do I put it on that green plate thingy? It was like connected. Can companies make reapair for that? Also before that the screen was plain white. Turned on white.. Didn't work but music still played on my I home... Also the procedure when I need to remove the bottom bottom top power button cord to volume button with scrape plate, I accidentally pulled and ripped that thin cord... Can anybody help me, is it possible I can get it repaired by a professional and ifi could what would be the price plx help thank you....
Add a comment
Add your answer
imrank15 will be eternally grateful.
Past 24 Hours: 5
Past 7 Days: 5
Past 30 Days: 8
All Time: 14,572
