Second generation of the Ford Focus.
95 Questions View all
Can I remove the hub and wheel bearing together when removing them
Can I remove the hub and wheel bearing together when removing them on front drive side it shows people removing bearings first then hub I'm buying the hub and bearings together and it shows both being put on together I have 2005 focus
Add a comment
1 Answer
There is an outter and inner wheel bearing the bearings will sometimes slide off with the hub or rotary, a sometimes they are pressed on the axel or spindle. Usually the outer will side of with the hub or axel, the inner bearing is the one that may be more difficult!
Add a comment
Add your answer
Trina Orrico will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 12
All Time: 34
