1.83, 2, or 2.16 GHz Core Duo processor
281 Questions View all
Being careful installed ifixit memory max we Ram Upgrade kit 2GB
I have a black screen after start up with the I fix it 2GB kit installed. I was very careful about static made sure to ground myself. When I put re install the 1 GB RAM originally installed (also an IFIXIT) (the data on the sticklers says exactly the same thing- 1GB DDR2 PC2-5300 667MHz except the PIN numbers. The original I took out says 204PIN and the ones I was sent say 200PIN.) Was I sent the wrong RAM? The chips look identical. Are they just miss marked? Is the one that works missed marked? What can I do?
Add a comment
1 Answer
Most Helpful Answer
Hi Rod,
This is the repair forum; iFixit Store doesn't come here to answer questions. You need to send them an email at support@ifixit.com explaining your situation. They are very good about their warranties and will be happy to help you out with your questions.
Score 1
Add a comment
Add your answer
Rod Mesa will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 4
All Time: 21
