Model A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac12,2
710 Questions View all
CPU Fan 0 RPM, Apple Hardware Test Error 4M0T/4/40000002: CPU-0
I bought this iMac used with a broken CPU fan (Macs Fan Control says 0 RPM) and CPU overheats easily . I bought and installed a used CPU fan off Ebay, but it didn't fix anything. I've already tried resetting SMC.
Is it possible for me to tap the CPU fan connector wire into the ODD fan connector or the HDD fan connector? (It's actually an SSD now.) I'm willing to remove the power from the other fans if you think that 1 socket on the logic board shouldn't power 2 fans. Thanks!
Add a comment
1 Answer
Most Helpful Answer
yes!! yes I have this setup right now when the HDD fan connector blew so im using the power from the ODD fan connector to power both fans !
its been like this for nearly a year and never had an issue
Score 1
1 Comment:
Thanks so much for the reply Teddy. Could you let me know how to do this? I have little knowledge of electricity and soldering, etc.
by
Add a comment
Add your answer
Adrian Phan will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 8
All Time: 99
