The Shark IONFlex 2X (model IF251) is a lightweight, cordless vacuum. It includes the handheld vacuum, motorized floor nozzle, wand, and two rechargeable lithium ion batteries.
16 Questions View all
How do I clean and lubricate the main vacuum motor?
The main vacuume motor is getting noisy like it's bearings or bushings are getting dirty and squealing. Is there a breakdown that shows how to clean and lubricate it? Thank you
Score 1
1 Comment
jasonrweaver just to verify, your vacuum is a Shark IONFlex 2X? If so, take a look at the answer on this Question and see if it works for your vacuum as well.
by
Add a comment
1 Answer
Most Helpful Answer
jasonrweaver I can’t find a service manual for your vacuum, only the instruction manual.
If you have a look at the device page, found here SharkIONFlex 2X, you will find guides on how to access the insides. Then you can determine what motor is in your model and if you are unsure how to proceed you can take high resolution pictures and update your question following this guide Adding images to existing questions
Score 1
Add a comment
Add your answer
jasonrweaver will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 35
All Time: 349
