LG 27 Inch UltraFine 5K IPS Monitor with macOS Compatibility
6 Questions View all
Replacement part for thunderbolt connector
Does anybody know where I can get a replacement thunderbolt port for this? The one I have is broken off from the board and damaged internally so it needs to be replaced but can't find the part anywhere.
Score 1
Add a comment
1 Answer
Chosen Solution
Hi
Unfortunately you can’t buy ports for this display so your only other option is to use one of the USB-C ports instead unless you have a donor board or can find a similar one
I suggest you watch this video as it goes into more detail
https://m.youtube.com/watch?v=zVmZby7Mug...
As they say in the video it’s quite common and you can’t buy replacement ports unfortunately
If you could find a pin diagram you might be able to find a similar port and try and solder it down to the right pins but I wouldn’t try it unless your comfortable with these sorts of complicated repairs
Hopefully this helps
Any questions please ask
Score 2
Add a comment
Add your answer
Darragh will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 14
Past 30 Days: 65
All Time: 1,818
