5g.hz wifi network is not showing some time
Name is not showing while in my other phone networks works prperly
Hi
This is a hard one to say as you would need a phone with the same WiFi chipset or the same phone to see if it’s a issue
5Ghz networks are shorter range but have better capabilities
The reason why other devices are picking it up and your one isn’t may be due to it having a different WiFi chipset
Different chipsets are good at doing different things so some might pick signals up better than others
If you are unsure about compatibility I would ask the manufacturer
I would also try restarting your device and restarting your router
It could be worth checking if your device need to have it turned on in settings too
Hopefully this helps
Any questions please ask
And it may be too far away
That’s another one:-)
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 6
All Time: 122
