The Nintendo DSi is the third iteration in the Nintendo DS line, and made its debut in Japan in late 2008.
264 Questions View all
Can the 3ds game cart reader be soldered in the dsi board?
My dsi stopped reading game carts, so I took a toothpick and lifted the "door" in the game cart reader in order to see the pins and they were bent (like 6 or 7, I also took it apart in order to make sure it was that), so I looked online for replacements, but I only found very expensive ones (I don't live in the us and purchasing on ebay isn't that reliable because of the shipping cost) and the only cheap one I found was a 3ds cart reader that looked almost the same as the dsi cart reader. Replacement cart reader images here.
Score 1
Add a comment
1 Answer
Most Helpful Answer
Hi
Yes you can solder a new one on but you might want to get some practice in first or have it done by a reputable repair store
If you decide to do it I recommend using a small soldering Iron tip with a quality solder ,wick and flux
If you are only using a soldering iron you might want to buy some chip quick as it melt’s very easily which makes it easy to take the old port off
Or you could use a hot air station to take It off ,just don’t use hot air for putting it on unless you get the opposite side of the board it the same area as you could melt the plastics on the connector
As for practice I recommend using some of those fault board and just try and take things off and put them back on
Hopefully this helps
Any questions please ask
Score 1
4 Comments:
I do know how to replace and solder things on a PCB, the question is, "Is the cart reader that I found compatible with the DSi even though it is advertised as a 3ds one?"
by
@angelcmhxd
Hi
I’m sooooo sorry about that
I mis-read the question
From what I know what and what I have read you cannot use the 3DS game reader on the DSI
However here is one that is compatible
https://www.ebay.co.uk/itm/115004732574?...
by
@hellomacos No problem and thanks for answering my question, sadly that item can't be sent to where I live, but I'll search for dsi cart readers somewhere else. :l
by
@angelcmhxd
No problem:-)
Please let me know of there's anything else I can help with:-)
by
Add a comment
Add your answer
AngelCMHxD will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 7
All Time: 62
