The Nintendo DSi is the third iteration in the Nintendo DS line, and made its debut in Japan in late 2008.
264 Questions View all
Why wont my DSi charge?
My DSi still has a little power in it, but whenever i plug my charger in, the LED light doesnt flash on and nor does the icon in the top right corner of the screen indicate that its charging. i tried cleaning the inside of the charging port with isopropyl alcohol but still no. it might just be a small problem with the charger but im not sure.
Add a comment
1 Answer
@keithluvsdano open your DSi and then plug your charger in. Use your multimeter and measure on the charging port pin to see if you have any voltage. If you do then you know your charger is okay. The DSi models have issues with bad charging ports. There are also 2 fuses on the board , one of them is charging.So check continuity on F1 and F2. Post some good pictures of YOUR Board with your QUESTION. That way we can see what you see. Adding images to an existing question
Add a comment
Add your answer
keith will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 9
All Time: 83
