The fourth-generation Surface Pro tablet, released October 26th, 2015.
210 Questions View all
Screen flicker/shaking after changing display
I replaced the display on an SP4 I have, and everything seemed fine. However, after now replacing the SSD drive I a running into an issue where after using the device for about an hour or so the screen starts "flickering", and shaking around.
I have read all about "flickergate" and the many suggestions on potential fixes with no change. (When the issue starts if I shut down and go into UEFI mode the issue remains).
Is it possible the fan is not starting up? Is there an easy way to tell without opening things up again?
1 Comment:
Well, I dont know if there is anything wrong with the fan - but def. confirmed its a heat issue. While watching a movie yesterday the screen started doing that thing - I used an upside down can of compressed air on the back of the device and the picture returned to noral. For a little while
I guess I will take it apart and check the fan - just dont want to go through all of that again
by
Add a comment
1 Answer
HI.
I had the problem of screen flicker when I replaced the screen on my tablet pro 4 with the spare part sold by ifixit. I finally had to opt for the Surface Pro 5 screen, which is compatible. You'll find my commentary on this subject here, which you might find useful:
https://fr.ifixit.com/R%C3%A9ponses/Affi...
Add a comment
Add your answer
Justin Greywolf will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 17
All Time: 89
