Repair guides and support for Gigabyte laptops produced since May 2003.
27 Questions View all
What Bios do I use for running linux on a GIGABYTE P17FV7
I am getting errors reported by Linux dmesg concerning "ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS07._UPC], AE_ALREADY_EXISTS (20210730/dswload2-326)" If I google the error it recommends tat I update the bios but does not give a bios version to update to. Which bios do I use for Linux and what version should I use to get over the error?
Dave,
Add a comment
1 Answer
Chosen Solution
There seems to be an incompatibility between the motherboard's BIOS/UEFI ACPI implementation and ACPI code embedded in newer GNU/Linux kernels. Redhat's online help center did in fact suggest to update the system's BIOS in case of ACPI error messages appearing at boot, but honestly I haven't found any info on whether Gigabyte was able to fix the problem. Anyway, the latest bios version from the vendor dates back to 2018, and it's v.1.05.03RGI5.
On bugzilla, a user recently reported he found a fix for his error "ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS07._UPC], AE_ALREADY_EXISTS (20210730/dswload2-326) [...]": supposedly, just disabling the sleep states in the BIOS did the trick (procedure changes depending on your bios layout, however generally under "power management" check ACPI_standby_state or suspend type is on S5/OFF)
Also, booting with uefi ENABLED and secure boot DISABLED was thought to be a possible solution.
Hope this helps, if any of these solutions worked for you please share it, your feedback will be useful for others with the same problem
Score 1
Add a comment
Add your answer
David King will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 10
All Time: 81
