A television game console produced by Sony Computer Entertainment; the PlayStation 4 Slim (CUH-2000 Series) is a thinner replacement model for the original PS4. Announced September 7, 2016.
571 Questions View all
Ps4 slim usb ports dont fit charging cable
I have a usb type A to micro b usb cable and it doesn't fit in the port on a ps4 slim. It looks too big. The console works fine its used the controllers work, does the slim model use a different cable or could it be the ports?
Score 2
Add a comment
1 Answer
Chosen Solution
Hi
Assuming that you are definitely using the right cable it should work
Some cables a built with a tolerance
For example if it’s half a millimetre too big it’s ok or if it’s half a millimetre too small it’s ok But that’s just a example and not actual information to go off of ,just a example
It might seem like it’s not fitting but if you get it in at the perfect spot it should fit ,but if it’s clearly not fitting don’t try it as it may cause damage
If you are having absolutely no luck follow this amazing guide to add some photos of it so we can see what’s going on a bit better:-)
Adding images to an existing question
Hopefully this helps
Any questions please ask
Score 2
Add a comment
Add your answer
Edward will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 13
All Time: 302
