Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2376 Questions View all
Why is the vibrator screws wont come out?
Im trying to tear down my iphone 4 and when i get to the vibrator screws they wont come out i tryed using a #00 philips screw driver and a pentalobe screw driver and it dosent help the screws just dont come out!
Score 2
Add a comment
1 Answer
Chosen Solution
Ofek,
I think these screws have thread locker on them, so it will take a little extra coercing to get them to come out.
I'm not sure how you would've used a pentalobe screwdriver on a Phillips head, but maybe your screws head is different?
Try to find the correct head if it is NOT a Phillips screw.
If you've stripped the screw head already, your options are to grab the outside with some sort of pliers and turn it that way, slot the screws with a dremel and use a small flat blade screwdriver, or you have to drill the screws out. None of these methods are very nice or pretty and you have to be extremely careful so you don't damage any surrounding parts. Good luck and I hope this helps.
Score 2
Add a comment
Add your answer
Ofek Ohana will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 2
All Time: 957
