Find solutions to your computer repair questions.
21270 Questions View all
Can I connect a 24 pin power supply to a 10 pin motherboard?
Hi!
So I am recently going to upgrade my pc with a few components and one that was required was a better power supply. So I went and found the perfect power supply for my needs apart that it is 24 pin and not 10 like my motherboard. I have seen a lot of people use adapters (24 pin female to 10 pin male) but I want to make sure if it's safe and reliable or maybe find a better solution.
Thank you.
Score 1
2 Comments
What is the brand and model of your computer?
by
@andrewsawesome I have a lenovo pc but I can't show you the exact model because I have broken my leg and I can't move to go and check the model
by
Add a comment
Most Helpful Answer
The part description says:
"Converts any standard ATX power supply to work with your 10-Pin motherboard"
Therefore, it must be OK.
But then I have never seen a 10 pin motherboard.
Score 1
2 Comments:
I have a Corsair 650 w power supply, will it be okay? If so, do I just buy a random adapter that I find or do you guys suggest any websites? I have some websites saved if you want to take a look and give a thought
by
If it states the above, then it is clear it is for that function. The 24 pin connector has a lot of duplicate pins for 12V & 5V. The 10 pin obviously does not have all these duplicates. I am assuming, since I have not seen a 10 pin MB, that the current requirements for the 10 pin MBs are much less than the 24 pins MBs which is why they use only 10 pins. You should be good with any of the adapters.
by
Add a comment
10 pin seems to be or is going to be the new standard, also know as ATX12VO. You can is this ADAPTER specifically for IBM/Lenovo.
Score 1
5 Comments:
Is there any way to DIY because the shipping is insane, 60 to 70 usd just for shipping
by
@irdi_j What country do you live in?
by
@irdi_j search for a 24 pin to 10 pin connector in your country. I do not recommend a DIY method unless you have no other option. This will require cutting , modifying and testing the voltage on each pin in both connectors and then re-pining the connectors. . Not to mention you will also need to short the green with ground wires in order for your new power supply to even turn on. Its doable , but not recommended unless you know exactly what you are doing. Sorry, i know this may not help but i highly recommend acquiring the proper adapter.
by
@cascara i understand
by
Add a comment
https://www.ebay.com/itm/155229445073
Add a comment
Add your answer
Irdi Jaup will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 26
Past 30 Days: 140
All Time: 4,894
