Seventh generation of iPad, released September 25, 2019, available in 32 or 128 GB models. Model Number A2197.
45 Questions View all
Can faulty iPad damage LCD panel
Hi, I have purchased a non functioning iPad for parts, as I wanted the LCD panel and digitiser and was told the LCD was still good.
After removing these and going to install in another iPad I discovered the LCD was completely dead. This was a little annoying, but I am now wondering if the iPad is still good.
If I was to put a new LCD in to test it, is there any chance a faulty iPad could damage this new LCD? I am thinking maybe a faulty board could send too much power and kill the panel?
If the answer is yes, can the connector be tested easily by a professional without installing a panel? Or is there a simple way to do this myself with a multimeter?
Thanks
2 Comments:
Hi, did you disconnect the Battery before you disconnected or connected the LCD? If not the Backlight filter or coil could now be broken.
by
Hi, yes I am always very careful about that.
I can see a repair has been done previously, it looks like maybe a charge port replacement, so am thinking either they weren't careful when disconnecting/connecting LCD, or board got damaged which may have in turn damaged LCD?
by
Add a comment
1 Answer
Hi
I know where you are coming from with your question I had it a while too
It really depends what the issue is with the iPad
For example:it isn’t going to damage the screen if it’s a speaker issue.Bit bare in mind that just a example
If you can roughy find the issue that will give a good indication of weather it’s good or not!
If you need help finding the issue please don’t hesitate to ask
4 Comments:
Hi, thanks for your answer.
That is the problem I have, I have no way to find the issue with iPad because I don't know if I should risk installing a new LCD so that I can test it 🤷‍♂️
by
@mclarenchris
What I would do is check the board for anything obvious like corrosion (looks like blue white green stuff)
Or anything that’s burned
If there is none of that ,me personally I would try it because I have done it 100s of times without any problems
But it’s not my decision to make,it’s up to you:-)
by
Thanks. I will inspect board and then decide.
Maybe I will sit on it for a while and see if I come by an already damaged but working LCD I could test with.
by
@mclarenchris
Go for it^_^
If there’s any thing you are unsure of just ask:-)
by
Add a comment
Add your answer
Chris Reader will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 390
