XBOX Series X - Turn on and then off - it wont stay powered on?
not sure what is causing this. I took it apart and inspected the motherboard. Everything looks fine?
If you want I can try to fix it for you
Im having the same issue, nothing wrong with the inside, how much do you think a repair would cost with this issue?
Edit, NVM, I think its the SSD, way out of my budget so I think imma tell my friend its a loss
Only thing other than people having same issue was YouTube repair video. And cable from power supply to motherboard the ground was charred. He ended up soldering the ground straight to board and it fixed. My cables are fine but wonder if it’s power supply or something else cause. It chimes on. Then right off. Took apart everything looked good. Out of warranty Microsoft wanted 300. With us ridiculous when it’s a manufacture defect (In my opinion) most expensive console ever and it didn’t last more than couple years. Even if i fix I’m moving to pc player. Really changed my opinion of xbox. 😞
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 34
All Time: 319
