How to swing the cooler air because it stuck one side
Plzz tell me itgotstuck one side
There is a small ac motor which works.like car wiper remove plastic shaft check if all flaps or one of this flaps are blocked hard remove main rotating plastic rod or replace it without load check motor running ya not check rotation switch.. at last change rotation motor it cost 250 rs pull out motor replacement with same size motor
@rajeevpawar if you ever get some pictures of all of that, it would be awesome if you could add those to your question Adding images to an existing question
it would be neat to see this since we don't have a lot of guides on this.
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 32
All Time: 62
3 Comments
Rohit Agarwal what got stuck? You have a Keystone KSTAD70A 70-pint Dehumidifier? Give us more information. Things like what got stuck, how did it get stuck, what have you tried to fix it, will help us to help you.
by oldturkey03
@oldturkey03 no I have kenstar cooler
by Rohit Agarwal
@Rohit Agarwal so a Kenstar Air cooler? What is stuck? What model is your air cooler?
by oldturkey03
