With a focus on gaming, the ASUS G501JW-BHI7N12 has features like a robust hard drive, higher end graphics card, and cooling fans to keep the laptop running smooth. It uses the same Core i7-4720HQ CPU that most other high-end gaming notebooks share alongside a dedicated GTX 960M GPU and a UHD (3840 x 2160) IPS panel.
11 Questions View all
TUF Gaming A15 has wifi disconnecting itself and more.
This has been happening for months now for my laptop where the wifi just disconnects randomly. It always does this, no matter if i redownloaded the pc or network reset. In addition, the wifi icon can sometimes even appear, so I cant even connect to a single network. Beginning to believe has its an hardware issues as i have tried basically every method, like wtih device manager, cmd, control panel, and systems. Nothing even works, this constant disconnecting is annoying but there is no solution on the internet. Also sorry for this but the device i choose is not the correct one, the one I have us the TUF Gaming A15 but I couldn’t find it at all.
1 Comment
I have the same issue where I do a speed-test and download speed is less than 1mbps .. I replaced the original Realtek wifi card with an intel wifi card .. same issues.
by
Add a comment
1 Answer
Most Helpful Answer
Hi,
Does it disconnect if you use the laptop <20cm from the WiFi router?
If not it may be a loose WiFi antenna connection in the laptop.
Here's a teardown video of the laptop that may help. The WiFi card and antenna can be seen being removed at 2:12 minutes into the video.
If it still disconnects, download, install and run this free WiFi sniffer program and find out what the signal strength is of your WiFi network that is being received by your laptop.
The signal strength values are in -dBm so the higher the number the lower the strength of the signal.
An excellent- good signal is considered to be between -40dBm to -60dBm, a fair signal is from -60dBm to -80dBm. After that it is problematical and you could start to experience problems i.e. >-80dBm. Too strong a signal i.e. -20dBm to -40dBm can also cause problems as it can overload the WiFi card.
Poor signal reception could be caused by external interference or perhaps even a faulty WiFi card.
Score 2
Add a comment
Add your answer
Yeet Tweet will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 27
All Time: 3,273
