JBL Flip 4 portable speaker. IPX7 waterproof bluetooth dual driver speaker that won the CES Innovation Award 2017.
83 Questions View all
Why do the power and sync lights dim when the bass hits?
Used it on my ATV numerous times it worked fine til awhile ago I started hearing crackles each bass thump when I pulled over to check it out (while still playing) I noticed the battery low and for some reason it seemed to drain energy from the LED lights? (Blue power light started to dim each time the bass was hitting same goes for when I turned on the sync light to check if it was just a bad LED bulb) what could be causing this (note the speaker wasn’t mine originally a friend gave it to me and it has been working fantastically til just today)
Add a comment
1 Answer
Most Helpful Answer
Whenever bass hits it consumes more current and uses ampere and voltages. If you have heavy speakers compared to the handler it normally happens. You need to use a high capacity transformer. Copper transformers are best for amplification.
Score 1
1 Comment:
It’s the portable Bluetooth speaker not their home speakers
by
Add a comment
Add your answer
Marcos Flores will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 12
All Time: 49
