The Officejet is HP's line of office inkjet printers.
358 Questions View all
HP 8610: One or more cartridges appear to be damage!
Hi, I turn it on, it complains about a damaged cartridge, so I open the front door to replace.
When I open the door, the carriage does NOT move, and the error message now says to close the door to print.
I close the door, and the original damaged cartridge error message returns.
I read some article that says you should downgrade you r firmware and I tried to go service menu by 4 taps on back icon on left side of screen, but I can't get to any service menu, and I have tried unplugging, waiting and plugging back in, and I have tried forcefully moving the cartridge, but nothing works.
Anyone has any experience about this error?
Thanks,
Score 1
Add a comment
1 Answer
well, have you tried replacing the cartridge?
8 Comments:
Yes, is there any way that I access to service menu when my printer has error?
by
let me check
by
if you open it then you can see a wire connecting to the cartridge , check that wire to see if its damaged
by
if that's not damaged then try to look at the connector between the cartridge and the connecter
the place where you place the cartridge
by
and finally yes, you can access to service menu when your printer has an error on these steps:
With the printer turned on, disconnect the power cord from the printer.
Unplug the power cord from the power source.
Wait 60 seconds.
Reconnect the power cord to a wall outlet and the printer.
by
Show 3 more comments
Add a comment
Add your answer
megan D will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 39
All Time: 1,245
