Model No. A1367 / 8, 16, 32, or 64 GB capacity
915 Questions View all
Blotchy area on new screen
My son dropped his iPod and broke the glass. I purchased a new screen with digitalizer attached, installed and closed it up. I then discovered the wifi antenna was broken. When opening again the layers of paper and such came separated from the glass. The new wifi antenna worked, and the screen still works. But now I have a greenish gray blotch right under the word iPod. The blotch seems to grow. I'm wondering if it is possible to fix this, or if I need purchase yet another screen and try again...
Score -1
Add a comment
Chosen Solution
docbill, probably not. It sounds like it has, or is, separating. Try to contact the vendor and see if you can get a replacement for it.
Score 1
Add a comment
PROBABLY THE PROBLEM IS WITH THE LCD QUALITY YOU HAVE BOUGHT BUT CHECK FIRST THAT THE SURFACE OF THE LCD FRAME IS CLEAN WELL AND YOU ARE USING THE RIGHT STICKER
(not so thick) during assembly coz, it will cause blotch when lcd surface is press. hope this will help.
Add a comment
Add your answer
docbill will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 4
All Time: 989
