Devices that create three-dimensional objects from digital files through additive processes using various materials such as plastic, metal or resin.
72 Questions View all
ender 5 plus. starts print but then damages pla and clogs.
i have ender 5 plus. it will start print great but after an hour or 2 it damages the pla at the gear and stops feeding pla. how to fix this. i have replaced with aftermarket feeder, new capricorn tube, new nozels and still same issue.
1 Comment
i have calibrated it
everything i try to print that takes more than 1 hour it acts like it has a clog in the head
the newest 4.11
i have a 10s pro as well and it works fine but this one has been a trouble since i got it.
i have replaced the main board twice and the power supply upgraded once as well as new tubes and 2 nozels. i even thought it might be a moisture issue so i got a dryer for the filament. nothing seems to help
by
Add a comment
1 Answer
Chosen Solution
Hey Danny,
Have you calibrated your Steps/mm?
What are you trying to print?
What profile are you using for Cura?
(Still new to 3D Printing, but also have an E5P so i’ve been doing a lot of troubleshooting myself)
Score 1
2 Comments:
the newest 4.11
by
Doesn't sound like a moisture issue.
- What mainboard are you using?
- What are your Steps/mm set to?
- 4.11 Default profile? or have you imported a profile?
- Do you hear any sounds after the hour mark? (Would indicate a clog)
- How close is your nozzle to the bed?
by
Add a comment
Add your answer
Danny Thompson will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 25
All Time: 513
