Self-priming automatic electric pumps with helical gears, produced by Marco.
28 Questions View all
UP12/E-LOBR for ATF oil coolig system?
Hello,
I,ve question is good option to built ATF oil cooling system for cooling electric motor with this pomp ? how long can this pomp work, and can i control flow parameter by the SCS or by simple valve ?
1 Comment
Hi @bedkowski ,
Perhaps @teof knows. You may have to wait for a response as this is a worldwide forum and different time zones means that there may be a delay before getting a reply. Hopefully not more than a day or two.
Moderator.
by
Add a comment
1 Answer
Most Helpful Answer
Dear @bedkowski, please write to export@marco.it for an analysis of your requirements.
Choosing the right pump is a matter of knowing the required flow, pressure and working cycles and our commercial department can help you with that!
Score 1
Add a comment
Add your answer
Bartek will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 13
All Time: 44
