The Nintendo DSi is the third iteration in the Nintendo DS line, and made its debut in Japan in late 2008.
264 Questions View all
Charger light blinking orange after fixing shoulder buttons
I’ve asked everywhere and tried everything on the web. I was fixing my shoulder buttons and my dsi stopped powering on. When I charge it, it flashes orange and will show the blue light and shut off. I’ve seen other people ask these questions and I never found an answer. My wish is to see my dsi working again. Please help
Add a comment
1 Answer
Chosen Solution
Have you tried a new battery? A blinking orange light means improper voltage. If that’s not the issue, it’s likely you have a charge chip issue or similar.
6 Comments:
it was working fine but the dsi just stopped working after assembling it. What’s the charge chip issue?
by
@eb200x Well first I'm assuming you checked the F1 and F2 fuses if you've already tried the web, is that correct?
by
i can’t because i don’t have a multimeter so what i wrote was false. But I do want to know other issues that could be causing this
by
@eb200x If it's not the battery or the charger or the charge port, then I suspect its a power board issue. Fortunately, its a pretty cheap part and not too difficult to replace.
Nintendo DSi Power Board Replacement
without a multimeter it's difficult to tell what exactly is wrong, but replacing this board should fix most if not all problems that cause blinking orange light that isnt the battery
by
I will try it thanks
by
Show 1 more comment
Add a comment
Add your answer
Shaun Jin will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 16
All Time: 167
