Device and repair guides for the Huawei P30 smartphone. Flagship smartphone from Huawei released March 2019, featuring a 6.1" OLED screen and an in-display fingerprint sensor.
79 Questions View all
P30 lite - not charging screen dimmed
Hello,
I got a P30 Lite that suffered water damage and would not turn on again.
I replaced the Main Board, charging board, cables,…etc. and now it starts but the screen is very dimmed. I could only see it with a flashlight.
I tried hard reset, tested with a new screen, another battery,…etc., same issue.
I also noted that when i connect the charger, the phone doesnt charge and the battery starts dropping down.
could this be a faulty main board? or other parts? I am lost.
Thanks
Add a comment
1 Answer
Chosen Solution
Hi @simbalux,
Was the mainboard new or guaranteed working OK?
Here’s a link that may help with the screen’s backlight problem.
Here’s a link that may help with the charging problem perhaps. You can only check to see as it could be something else e.g. was the charge daughterboard water damaged as well and did you replace it also?
Score 2
1 Comment:
Many thanks for your help.
In fact, the replacement main board was taken from a used phone with broken lcd, i bought it online so not sure if it was also 100% ok.
by
Add a comment
Add your answer
sam will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 9
All Time: 364
