Repair guides and information for kitchen food scales.
27 Questions View all
Why does my scale not read reliably or return to zero reliably?
Duronic kitchen scales KS865 - wheatstone bridge strain gauge-based balance.
The scales tare correctly, but when I place an object of known weight on it reads low. When I take that object off it does not quite return to zero. The scales have recently been dropped.
Add a comment
1 Answer
Chosen Solution
I found that the load plate (top part) of the scales had become slightly twisted in its mounting (through the strain gauge) to the base of the scales. This was causing the load plate to rub slightly on the base and make the readings unpredictable. By slackening the two screws that mount the load plate to the strain gauge, and realigning, I was able to get the scales working perfectly again.
Add a comment
Add your answer
dan_6384856255 will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 18
All Time: 98
