Televisions made by the Chinese multinational electronics company, TCL.
267 Questions View all
Half of screen has no backlight
Only part of my TCL 65Q825 screen has no backlight. I'm assuming these local dimming zones are not working. What would be causing this? The TV is only about 1.5 years old and I would like to fix this if I can.
Thank you!!!
Score 1
Add a comment
1 Answer
Chris Frasca this could be due to failed LED’s on the backlight strips. You will have to disassemble your TV right down to the panel. Then open up the panel and replace the strips. It’s a bit of a PITA but not to difficult. When you take teh panel apart you will come across a couple of “plastic” sheets. Those are diffusers, polarizers etc so do not mix them up, keep them in the same order and the same direction. Of course, you always want to check the power board output to the LED strips. Use a multimeter and measure the voltage on those. You should have the same voltage on each connection. Set your meter high since there should be a couple of 100’s volts on it. If you need more help with that, post some good pictures of all of your boards with your question. that way we can see what you see and hopefully help you a bit more. Adding images to an existing question
1 Comment:
Tested all the lights they are all good ordered new boards will update when i get them.
by
Add a comment
Add your answer
Chris Frasca will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 12
All Time: 85
