Apple's 6th revision to the iPod Touch lineup, released in July 2015.
149 Questions View all
What is the middle battery connector for?
After Ipod touch battery replacement the battery has been getting stuck at 19% or less
then when it gets low enough the ipod shuts off,
and it take a while to get it to start up again with it plugged in,
Is it possible i got a defective battery?
Score 1
14 Comments
@beanman56 it's possible. where did you get it from?
by
I got my battery from ifixit,
so whats the middle connector for?
by
@beanman56 On the 6 gen I am pretty sure the centre pin is the battery data.
by
Is it needed?
Cus it was ripped off the board
by
@beanman56 Usually one or more pads come off when this happens. How’s you’re soldering skills?
by
Show 9 more comments
Add a comment
1 Answer
Chosen Solution
Hi
Hope you are well
I did not know really know how to explain this but I had a 6th gen that had the middle battery connection ripped off from previous repair and I noticed that mine would get stuck at 17% and when it would die it straight up wouldn’t charge again but there are test pads above the 3 battery pads and I found the one in the photo had a connection so I ran a jumper and it started working again so hopefully my complex explanation as helped
Anymore questions please ask
Score 2
10 Comments:
Whats a jumper
by
@beanman56 A jumper is copper wire that you use when a trace or pad is broken between components. The average size wire is 0.01mm
by
@hellomacos - What size should said jumper be?
by
@beanman56 where you been Sir? Doing ok?
by
Show 5 more comments
Add a comment
Add your answer
Ben Capehart will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 26
All Time: 308
