0
Score
alberto
Asked
a picture its just complete darkness
Panasonic Lumix DMC-TZ2
Hello, i have a problem whit my a DMC-TZ2 camera, when i turn the power on it goes on normal except it wont display any picture when on taking picture mode. you can however view the album but it takes black pictures. i can see the lens open and close when you click to take a picture but its just complete darkness. nothing comes out. it even flashes but will not take capture anything the screen is just black
Thank you
Score
oldturkey0
88.1k
Answered
alberto, try this " To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter."from here. If you are absolutely sure that your shutter is working, you should replace your CCD and check the cables for proper placement and that they are not frayed or broken. the service manual is available for you right here Hope this helps. Good Luck
hi, The shutter is not stuck, I can see movement by making a photograph,the shutter opens and closes Then, I should replace my CCD. Where I can buy a CCD? Excuse my bad English and thank you very much
alberto, your English is fine:-) The part number is VEK0L03 and the part is avaialble at places like this http://www.partstore.com/Model/Matsushit... Good Luck
the price of the CCD is very expensive!! I removed the cables and all are well. I removed the shutter and zoom engines and all are well. I checked the optocouplers because the camera gives me this error: 18000300 ENC1 detect error (C.B. motor encoder detect error). FP9802-(10) signal line or IC6001 (VENUS 3) It does not work, I've tried. the problem is the CCD CCD will try to find a cheap or second-hand camera. thank you very much!!
0
Score
Diego
Answered
Alberto pudiste reemplazar el CCD? Tengo una Panasonic Lumix DMC-TZ3 con el mismo problema. Posiblemente compre el repuesto en e-bay pero no tengo referencias si es fiable.
No lo he reparado, cuando busque el CCD su precio era muy elevado, rondando los 100€, vamos que podía comprar una nueva cámara. Por que precio lo has encontrado? la cámara aún la tengo y de vez en cuando busco CCD. Un saludo
Soy de Argentina, el costo de la reparación en un service es de U$S 90 (repuesto + servicio). En eBay encontré muchos ofertas entre U$ 24 y U$ 50 con envio gratis. Me parece raro que salga 100€ Habrá alguna diferencia de calidad de estos CCD? Te paso los link de eBay... http://www.ebay.com/itm/NEW-image-sensor... http://www.ebay.com/sch/i.html?_sacat=0&...
Diego, the cost is higher since the service center will have to make money as well. Everybody has bills to pay and needs to make a profit. I checked your parts and I would not hesitate to get it and repair the camera myself. The only place that will use original parts is an authorized factory service center, most other places will use aftermarket pieces. Hope this makes sense, thanks Google. Google Translation " el costo es mayor, ya que el centro de servicio tienen que ganar dinero también. Todo el mundo tiene cuentas que pagar y necesita obtener un beneficio. Revisé sus partes y yo no dudaría en hacerlo y reparar la cámara yo mismo. El único lugar que se utilice piezas originales es un centro de servicio autorizado de fábrica, la mayoría de los otros lugares se utilizan piezas de recambio. Espero que esto tiene sentido, gracias a Google.
0
Score
Diego
Answered
oldturkey03
La traducción de google esta muy bien.
Solo puse valores de referencia de mi país, porque me pareció excesivo el costo del respuesto que comentó Alberto (€100).
Estoy de acuerdo con que el servicio gane por el trabajo, pero pongo en duda que en mi país utilicen repuestos oficiales y me parece un valor excesivo considerando que la cámara tiene un precio de reventa de U$ 200.
El 99% de las personas usan el servicio técnico porque no conocen como hacerlo ellos mismos y tampoco quieren conocer, yo soy del 1% que me gusta interiorizarme en estas cosas.
Por otro lado partstore.com no indica mucha información del producto, ni siquiera una foto. No dice si es un repuesto original y certificado, por lo cual me pregunto… donde consigo un repuesto original Panasonic? Y cuál es la diferencia con lo que se consigue en eBay?
The google translation is very good.
My intention was to show reference values of my country, because I think it is excessive replacement cost which said Alberto (€ 100).
I agree that the service gains through work, but I doubt that in my country using official replacement parts and value seems excessive considering that the camera has a resale price of $ 200.
99% of people use the service because they do not know how to do it themselves and do not want to know, I am the 1% I like to know these things.
Also partstore.com not indicate much product information, not even a photo. It does not say if the original part and certified, so ... I wonder where it a Panasonic original part? And what is the difference between what you get on eBay?
La verdad es que cuando busque en su día el repuesto solo lo hice por su código del service manual VEK0L03, creo que es el mismo para la TZ2 Y para TZ3. Todos los resultados fueron precios excesivos. Ahora viendo tus busquedas en Ebay la visión de la reparación ya es distinta y asequible. No puedo decirte si los CCd se diferenciaran en algo, en los linq que has enviado no hacen referencia a VEK0L03, esperemos que estos repuestos sean compatibles. No se si has comparado tu CCd con las imagenes, son iguales?? yo no he podido comprobarlo. Si estos CCd son compatibles probablemente realice la reparación. Un saludo!
Yes, that number is correct. VEK0L04 is the number for the CCD. The original Panasonic part is very expensive. At places like this http://www.pacparts.com/part.cfm?part_no... it still cost $130. That is for an original Panasonic part. So, I would contact the ebay seller and ask for clarification to make sure the part will fit. Also, pay through paypal and use ebay for checkout, that way you have buyer protection. Google Translation: Sí, esa cifra es correcta. VEK0L04 es el número de la CCD. La pieza original de Panasonic es muy caro. En lugares como este http://www.pacparts.com/part.cfm?part_no... que todavía cuestan $ 130 Eso es para una pieza original de Panasonic. Por lo tanto, me gustaría contactar con el vendedor de eBay y pedir una aclaración para asegurarse de que la pieza se ajuste. Además, pagar a través de PayPal y eBay para usar la salida, de esta forma usted tiene protección del comprador.
