Part of Google's third generation of Pixel phones, the 3a is a budget-minded option with the same camera as Google's flagships. Available in Clearly White, Just Black, or Purple-ish. Released May 2019.
70 Questions View all
Replacement screen not working properly for dimming below 30%
I finally installed my replacement screen from ifixit yesterday, double checked it worked by turning on the device, before I glued it in place. Unfortunately I did not check the screen functions more thoroughly. When the screen brightness dips below 30% the backlight doesn’t continue it's gradual dimming, but shifts to a dark reddish hue making the screen unreadable at low brightness. Is this a known issue or easy to fix? May it be because of a faulty connection between the screen and the phone or is it a defective screen?
Thank you in advance for any assistance on resolving the issue.
Add a comment
1 Answer
Chosen Solution
Sounds like it could be one of the following:
Bad connection - Reseat LCD ribbon cable
Backlight circuit damage - Caused during the repair would need to be tested with the multimeter
Or and god forbid it, but maybe the screens a dud. 1 in every 10 screens we buy-in for our customers seem to have a slight defect or just dead on arrival from the suppliers.
I would try reconnecting the LCD first, give the phone a force restart, this can help. Then put a support request in with iFixIt, while you wait, see if you can find a bad backlight circuit on the board, if there is one.
Score 1
Add a comment
Add your answer
Martin Fischer will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 9
All Time: 181
