Score
Shane Dulong
13
Asked
Can I fix my headphone jack without disassembling?
My headphone jack has gone bad again... One of the channels won't work. Can I fix it without disassembling the iPod? Could I use a needle to move the leads or something?
I had a 3rd generation and the same thing happened. Christmas was coming and I was likely getting a 4th gen, so I decided to try taking it apart (The screen was cracked too. Not much to lose.). It didn't go to well... I'm a salvager not a repairman...
Edited by: mayer, oldturkey03, rj713, osvaldo, and machead3 ( )
4
Score
pollytinto
39k
Answered
Accepted Answer
You could try.. But if that doesn't work the part needs replacing so you'll have to open it up. Use a toothpick so you don't short anything, this may just be dust or dirt on the prongs
Thanks pollytintop! I figured it was a bent lead but it turns out it was just dust. Once you said that I got an air compressor and blew out the dust (From a bit of a distance of course. Didn't want to blow my iPod inside out...). It worked great! Saved me some money and kept me from taking a huge risk.
2
Score
Jason
367
Answered
Try twisting and lightly pulling (without disconnecting it) on the headphone and see if you can get some sound. If so then it probably is something in the jack itself. If not the jack itself will probably need to be replaced.
Great job listening to pollytintop. Now, all you have left to do, is accept the answer. That way people with the same problem as yours will know what to try and what works. Again, great job.....;-)
oldturkey03,
