Known as the ''PS2'', it is a sixth-generation video game console first released by Sony in Japan in March 2000. The United States saw it later in 2000 with the SCPH-30000. Repair of this device requires only common tools, but can get tricky.
200 Questions View all
Why the hecc is my Playstation 2 doing this?
So I’m having issues with my Playstation 2. For some reason, my PlayStation 2 has weird graphical glitches (Screen flickers colors, goes in and out of signal). It was working perfectly fine before all of this. Is there a fix to this?
Add a comment
1 Answer
Chosen Solution
Are you running with the original, or older cables? A lot of the time, this is cable or TV related. First thing I would try is a replacement cable - these are all over eBay and in many gaming stores. You will not be able to get an OEM Sony one these days (new, at least) but the 3rd party ones work well enough considering the resolution here. If that fails, hook it up to a different TV or if you can do so, try to find a projector to make testing this easier.
If neither works, it’s usually a connector or board issue - commonly bad capacitors.
Score 1
Add a comment
Add your answer
KOOL -AID will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 44
