Repair and support for the controllers that shipped with the PS3. Released in November 2007 (Japan only) and 2008 (other countries), the six-axis lithium battery powered controller (CECHZC2) is straightforward to repair.
157 Questions View all
How do you fix a stickey L3 joystick?
My L3 joystick is sticking to the left as if I am doing it. When I lift my thumb it keeps moving left or turning my shooter. Is there a repair or fix and where can I get the info. Yjanks
Add a comment
1 Answer
so when you take your thumb off does the thumb stick pop back to neutral?
have you spilt anything on it recently? you may need to open it up and clean out the joy sticks.
that’s not too terribly hard to do.
if the thumb stick does not pop back to place then you may have to either resolder a new thumb stick.
if its moving when the thumb comes back to neutral and it still drifts unfortunately the thumb stick has stick drift, usually you can set dead zones in games to reduce how bad it drifts but it’ll only get worse with time.
Add a comment
Add your answer
xxrudexx will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 11
All Time: 79
