Updated Apple TV with second generation A5 processor / Released March 7, 2012
32 Questions View all
It's not discovering any wifi or even bluetooth. (Apple TV 1427)
My Apple TV 1427 is not discovering any wifi or even bluetooth. Tried after updating software with direct cable connection. Even then it is not working. Reset, restored and software update, all tried but to no avail. Kindly let me know what could be wrong and how to solve it. Thank you.
4 Comments
Do you have the ability to open it up?
by
I will be happy to try. Thank you.
by
Right now as a last attempt, I've connected it to MacBook Pro and started restoring/updating it. I'll post the result once I'm done.
by
I've done restore/update through connecting to iTunes n MacBook Pro. But this has also not helped. It appears it is a hardware issue. Kindly help me. Thank you.
by
Add a comment
1 Answer
Chosen Solution
Sadly, there’s not much you can do here.
Clearly your logic board has failed so you’ll need to find someone with the needed skills to fix it, if that is possible. The problem is the cost of a new unit is likely cheaper than either finding another logic board or the cost of repairing if that’s possible,
Review this Apple TV 3rd Generation Teardown as well as Apple TV 3rd Generation Logic Board Replacement
Apple TV 3rd Generation Image
Guide
Difficulty:
Moderate
Apple TV 3rd Generation Logic Board Image
Guide
Difficulty:
Moderate
10 - 15 minutes
1 Comment:
Thank you so much for sparing your valuable time.
Let me use it as a paperweight!!! That's the only option left now!
by
Add a comment
Add your answer
Venkat will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 18
All Time: 88
