Lenovo IdeaPad, Yoga Series. Released October 2013, 13.3 inch screen, 8 GB RAM, 2 GHz CPU, 512 GB SSD.
16 Questions View all
Lenovo Yoga Pro 2 not booting
Yesterday while using my laptop the screen suddenly distorted badly in what seemed like an odd crash. I turned it off, put it aside and let it be until today. When I try to turn it on, there is no picture or backlight. The keyboard lights up for ~4-5 seconds, the power button stays on for about 9, and the charging light slightly less than the power button. It continues this cycle seemingly indefinitely so far, unless I hold the power button to turn it fully off. My theory is the it might have something to do with the CPU, but I’d like to get advice from people much more knowledgeable.
As a side note, after several minutes of leaving it ‘on’ the fan has begun to spin. Also pressing Caps Lock does not turn on the little indicator light. Not sure if that helps narrow anything down.
Add a comment
1 Answer
I have had this problem with my yoga-730 after I replaced the keyboard and other things. Each time it was something different so it's just a lot of troubleshooting. You may have to unplug the display connector then plug it back in. One time I took out my RAM stick and it started perfectly I don't know why that worked but that happens a lot lol. Try different things and they may work you never know. It is also good to read the manual made by Lenovo, this can open your eyes to new things you never knew about your laptop.
https://download.lenovo.com/consumer/mob...
It's right here^^
Let me know how everything goes. Good luck!
Add a comment
Add your answer
Matt will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 21
All Time: 260
