Released September 20, Apple's mainstream 2019 iPhone comes with a 6.1" LCD touchscreen, dual cameras, and six available colors. Successor to the iPhone XR.
481 Questions View all
iPhone 11 front camera not working with new front camera assembly
I have a iPhone 11 which has a broken face-id and non-functioning selfie camera. I decided to order a new front camera assembly as that would at least restore the front camera however it doesn’t appear to work. I was wondering if this is a paired component and therefore I would need to go to Apple or if I have damaged something.
Score 2
2 Comments
It could also be that you have received a broken frontcamera .
by
What if I restored it would it maybe work then?
by
Add a comment
1 Answer
Most Helpful Answer
The front-facing camera assembly is paired in that the FaceID will no longer function however the camera should still operate fine for pictures/video.
If you’re having issues with no camera display, you can 1. clean all the connectors with iso alcohol and make sure they aren’t loose on the board 2. factory reset the device to remove any conflicting apps or corrupt data that could be causing it 3. try the camera in another device or try another camera in your device, the assembly you have may be faulty.
Score 2
Add a comment
Add your answer
Jason Brooks will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 17
All Time: 258
