Model A1418 / Late 2012 / 2.7 & 2.9 GHz Core i5 or 3.1 GHz Core i7 Processor
212 Questions View all
No sound. No Internal Speakers in 'Sound' window in Preferences
Late 2012 model A1418/2.7GHz Core i5 — installed 1TB SSD and 16GB memory. Fresh install of Catalina and migrated data from late 2009 iMac via Time Machine. Every time there was very good audio from the usual start up sound (which would indicate to me that the internal speakers are functioning well). In the process of confirming all files had migrated and checking functionality of everything, I noticed the speaker icon in the top bar was grayed out. Opened preferences, sound window — in the ‘Output’ tab there is no ‘Internal Speakers’ shown. Spent quite some time on line with Apple troubleshooting the issue. Tried finding and cleaning up some files to enable resetting and identifying the speakers — all to no avail. Took computer to local Apple store — they tried everything they could to resolve via software — no change. Next thing Apple said they would need to do is start replacing hardware (obviously too costly for age of computer). First thing they were going to replace was the logic board. Is there other piece of hardware besides the logic board that would have an impact on the unit recognizing the internal speakers? I’m sure the speakers are fully functional since the sound is quite loud at the startup sound.
Thanks
Update (01/16/2021)
I forgot to mention -- tested output from headphone jack with plug-in apple earbuds - had sound but only on one channel, could not adjust volume. Tried battery powered external speakers that plugged in to the headphone jack -- relatively low audio on only one channel. Also tried USB headphones - no audio.
Score 1
Add a comment
1 Answer
Most Helpful Answer
I bet you you forgot to connect the headphone jack! Review Step 57 in this guide iMac Intel 21.5" EMC 2544 Logic Board Replacement. If its connected then it maybe damaged.
Score 1
3 Comments:
Certainly not impossible that I forgot to reconnect or properly seat the cable for the headphone jack. I now realize I did forget to add the following detail that was part of my troubleshooting:
by
@kroto - Sounds like you damaged the ribbon cable, here's the needed part iMac 21.5" Headphone Socket and Cable, Apple P/N 923-0449
by
@danj Thank you Dan! Really appreciate your quick responses. I will order the replacement cable with great anticipation that it will resolve my problem. Thanks!
by
Add a comment
Add your answer
Kroto will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 233
