The GameCube is Nintendo's fourth console gaming system. Repair is simple and requires only common tools.
91 Questions View all
Why is there no video?
So my GameCube has no video, but it has sound. Further inspection shows that only the red input is working and not the white and yellow.
i tried switching cables and that didn’t work.
thanks in advanced
2 Comments
Hi,
Have you proved that the the AV input (yellow - video + red & white - left and right audio) on the device (is it a TV?) that the game cube is connected to is working OK, you didn't say? You only said that you changed cables.
Try connecting another device that has an AV output to the device, e.g. a dvd player and check that there is video and audio when using it to determine whether the problem is in the game cube or not.
by
Hi! So I tested the same cables and TV with another GameCube I have, and it works fine.
Thanks!
by
Add a comment
Chosen Solution
Hi,
Here’s a video that may be of some help with locating the problem.
Also here’s the ifixit Nintendo GameCube guides as well which may help with getting access to the component parts
Add a comment
How about check to see if the video connector has a bended pins or damaged pins?
1 Comment:
There at no bent or damaged pins
by
Add a comment
Add your answer
David Lank will be eternally grateful.
Past 24 Hours: 4
Past 7 Days: 46
Past 30 Days: 192
All Time: 7,222
