Model A1320 / 8 or 16 GB capacity
156 Questions View all
iPod Nano 5th gen only works when docked
I dropped my ipod nano 5th gen. When it is docked, everything works great, but it powers off instantly when unplugged, and when it is re-docked, it boots up as if it shut down due to battery failure. It will then indicate that the battery is charging, but even when I wait until it says the battery is charged, it will still power down when undocked. The battery was in great shape prior to me dropping the thing. Could it be as simple as a loose battery connection, or am I SOL here?
Add a comment
Chosen Solution
It could most certainly be a loose connection, as well as an internally damaged battery. Other than opening it up (PITA) and changing it, not much you can do. The indication that there is something wrong with your battery, is the fact that it works well on AC...iPod Nano 5th Generation Battery Replacement
Score 2
Add a comment
Telltale sign that the battery ribbon is loose. Need to resolder it back on.
Add a comment
Add your answer
ben will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 13
All Time: 1,988
