Kurio 7S 7 inch Android Tablet is most commonly used as a family or children's tablet, as it is preloaded with 60+ interactive apps. Popular features include a multiple profile capability with fully customizable Parental Control settings and safe online play. Model number: C13000
6 Questions View all
Kurio wont turn on
My son's kurio has decided to just stop turning on. I've tried different chargers, I've checked the charging port which seems fine. This happened once before but, I just left it charging for a few days & came back to it & it turned on. But, this time it's not turning on at all. Any other things I can try or is it time to just buy a new tablet? He loves this tablet! I really don't want to let it go.
Add a comment
1 Answer
Hi @momomckh ,
Some things to try:
a). Try resetting the tablet by gently inserting a straightened paper clip into the tablet’s Reset hole and operating the reset button for 5-10 seconds and then remove. You should feel the reset button operate as you insert the paperclip.
Here’s an image taken from the user guide that shows the location of the reset hole.
(click on image to enlarge for better viewing)
b). Try a hard reset and check if the tablet starts OK and then turns on etc. Be aware that a hard reset will erase all your personal data and downloaded apps from the tablet. It will be like when it was first bought.
c). Open the tablet and inspect the micro USB charge port to ensure that it is not loose from the systemboard thereby prevent the charger from either starting the tablet or charging the battery so it can be used to operate the tablet.
Add a comment
Add your answer
Clarissa will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 31
All Time: 420
