The 2004-2008 F-150 truck was introduced in January 2003 for the 2004 model year as the redesigned eleventh generation of the F-150 lineup.
56 Questions View all
Howdo I narrow down whether its the resistor or the speed control swit
I have power to the motor. And have checked it with voltmeter. Replaced the resistor. No luck there so I checked the speed control switch and it is melted a little on the connector and there isn't any resistance on the switch. I tried jumping the switch but nothing happened there either. So now I want to check the connector on the resistor. However I can't find an help with that.
Score 1
Add a comment
1 Answer
Most Helpful Answer
Hi @fordfun ,
Do you mean the blower motor resistor?
Here is an image from the repair manual, showing the circuit for a 2005 F150 auto and manual A/C blower motor and motor resistor.
(click on image to enlarge for better viewing)
Here is the rest of the repair manual in case you need more information.
Score 1
Add a comment
Add your answer
Jeramie Millhouse will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 8
All Time: 104
