Larger version of the Nintendo DSi, released March 2010 in North America. Most repairs are accomplished with only a screwdriver and prying tools.
157 Questions View all
dsi xl charge port ripped pads
so i tried to repair my dsi xl because it had a bad charge port, and i had bought a replacement charge port but when i went to try and take out the faulty charge port, i had ripped 4 pads out if the motherboard. the pads where the 4 pads all next to each other. and yes i have solder experience but this was my first time replacing the port
Add a comment
1 Answer
Hi, sorry i come almost three years after the "war". Don’t worry about judgment here, all the people who try to change a port of a ds know the complexity of changing it (and I’m not saying that because I’ve already changed at least 30 ports and I still sometimes brought pads!^^ ). There is still a way to save this motherboard, if in the three years she was not finished in the trash or in donor board, just put a "'jumper wire" you have to solder to the part of the port that no longer have a pad, follow the line of the pcb and remove the green protect on the pcb to be able to solder the cable and do it for the four, here is a video that will explain better than me and shows how to do (not on a ds but that explain the process) https://www.youtube.com/watch?v=AR0lb7YI...
Add a comment
Add your answer
Eduardo Bustamante will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 6
Past 30 Days: 17
All Time: 59
