Released in North America in November 2006, the Wii was Nintendo's first home console to directly support Internet connectivity, supporting both online games and digital distribution of games and media applications through the Wii Shop Channel.
289 Questions View all
Why is my Wii producing a dark picture?
I got out my old Wii that worked fine for the longest time with no issue, one day I go to turn it one, and the picture displayed is very dim and hard to see but there is still one. I know it is not the tv or the power cable as my grandparent’s Wii still works perfectly and theirs still works fine with my cables and on my tv. What could be the issue and how would I fix it. If I can’t fix it is it possible to get another Wii and transfer the data over to that new one?
Score 1
Add a comment
Hi!
Which cables are you using? The regular AV cables? What you can do: Buy and try the composite cables. Perhaps this will work.
Side-Note: It also could be your AV port which is damaged or something went wrong with the GPU.
2 Comments:
I am using composite cables, and the port does not look damaged, so could the only remaining thing be the GPU?
by
Could you otherwise try the regular AV cables? Sometimes mixing it up (composite) is causing this.
by
Add a comment
MattKC did a video on dim wii video! though it is really difficult to fix if you plan on doing it yourself. https://youtu.be/sdWmm33VzBM
1 Comment:
it might have something to do with the video capacitors on the motherboard. They're connected to the AV chip and port. though replacing the bad capacitors is really difficult.
by
Add a comment
Add a comment
Maybe buy a second AV cable to test that it's not the cable itself. If that does nothing, try a nice old power wash of a q-tip and alcohol, if neither work, just follow MattKC's video
Add a comment
Add your answer
hexagonalyeti will be eternally grateful.
Past 24 Hours: 7
Past 7 Days: 66
Past 30 Days: 288
All Time: 10,679
