Media players with CD read capabilities
100 Questions View all
Releasing a ribbon cable from the mother board
I have a Pioneer CD player with a bad optical pickup assembly. The ribbon connector attaching it to the mother board will not release. The connector has no visible tabs to press or lift and appears to be a solid block soldered to the mother board. How do you get the cable released?
Update (11/01/2020)
Pioneer PD-M500 CD Player
Add a comment
@jbtjr we will have to see what kind of connector this is. There are plenty of them around and unless we can see your connector or at least a model number, we cannot answer this. Adding images to an existing question
Add a comment
I got it! The ribbon is just a friction fit into the connector. It was tight, so you have to pull straight up with a steady but very firm pull and it came out. Problem solved!
Add a comment
Add your answer
John Todd will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 179
