Released December 3, 1994 in Japan and September 9, 1995 in North America. Models SCPH-100x, SCPH-3000, SCPH-3500, SCPH-500x, SCPH-550x, SCPH-700x, SCPH-750x, and SCPH-900x.
73 Questions View all
Accidentally tore off optical drive power supply cable socket
While doing repairs I realized I had torn off the optical drive power supply cable socket from the motherboard. That's the white plastic thing with the metal parts. The metal pins are intact. Should I solder then back on? If so, do you have any tips?
1 Comment:
@voidemissary post some good pictures with your QUESTION showing what the damage looks like.
Adding images to an existing question
by
Add a comment
1 Answer
I can’t see if the solder pads on the board are damaged or not, from the look of the pins you should be fine.
It won’t be a difficult job but always practise first if you aren’t sure of your abilities. Use a small amount of solder to help reflow the existing solder on the pins.
2 Comments:
Should I add solder to the pins or the board? And should I add solder to the sides of the plastic socket where the broken off metal is?
by
Sorry, haven't logged in in a while.
Small amount of solder to everything I think, but just enough to leave a very small coat. Solder the metal at the sides, that could be an earth connection.
by
Add a comment
Add your answer
Egg will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 13
All Time: 61
