An LED smart TV released by Samsung in 2013.
18 Questions View all
Has power but no display
I have power to the tv because I installed lights that connects to USB port in back but the screen no long have a picture or when you turn it on where it has the box that tells you that you have no connection any longer. I took the lights off to see if that changed anything but it didn’t. Still turns on but I still have no lcd display. Any suggestions
Add a comment
1 Answer
Most Helpful Answer
rscillion0311  all that the lights installed show you is that your USB port gets power. You will have to remove the back cover from your TV and take a look at the power board as well as the main board. Measure the voltages on the power board and let us know what you get. Disconnect the wire from the power board to the main board and see if your TV’s backlight comes on. Post some good pictures of your boards with your QUESTION. That way we can see what you see. Adding images to an existing question
For now, this does sound like a power board failure.
Score 1
Add a comment
Add your answer
rscillion0311 will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 12
All Time: 255
