Formally called the Chevrolet C/K, C/K is a series of trucks manufactured by General Motors and marketed under the Chevrolet and GMC brands. The C/K line includes pickup trucks, medium-duty, and heavy trucks.
299 Questions View all
Steering column swap 88 to 89
Can the steering column from an 89 be swapped into the 88?
Score 2
2 Comments
This is a K1500 chevy pickup.
by
Yes it is thank you
by
Add a comment
Chosen Solution
Check with a junkyard--they have a manual showing where parts can be used from one vehicle to another.
Score 5
3 Comments:
I didn't know that thanks
by
What model will fit a 1996chevytruck steering column
by
But I said 1996
by
Add a comment
By comparing some numbers the 88-94 Chevy 1500 2500 Suburban, 2wd or 4x4 GMC Sierra 1500 2500 will all work. Verified by Hollander Interchange that they do fit. Hope this helps....good luck.
Score 4
7 Comments:
Can anyone tell me what steering columns are compatible with a 1991 GMC C 1500 sierra
by
Hollander huh
by
Ok what years are compatible with a 1991 GMC Sierra
by
Just in case this w help someone.the 1998 gmc sierra steering column is by itself no others fit
by
What steering column will match up with a 1989 Dodge 4/4
by
Show 2 more comments
Add a comment
what other year steering columns will fit in my 95 silverado 1500 automatiac
1 Comment:
I'd like to know if a 1997 z71 steering column can be swapped with a 1998 z71 steering column???
by
Add a comment
1990 Chevy suburban 4x4 350 700 r4 tans will a GMC steering column swap work
Add a comment
Will a Steering column off a 1995 Chevy Silverado 1500 fit on a 1995 GMC Sierra 1500 ?? Someone Please Let me know ❗
4 Comments:
yes it will i put one in a 95 gmc i owned swapped right over
by
Would someone please tell me what will swap out with a 1992 chevy steering column
by
88-94 GMC/Chevy full size trucks or vans,Tahoe's/Yukon's!!
by
Can u swap a steering column from a 91 Chevy 1500 automatic with a 92 Chevy 1500 5 speed
by
Add a comment
Add your answer
Steve will be eternally grateful.
Past 24 Hours: 7
Past 7 Days: 15
Past 30 Days: 65
All Time: 24,813
