Device and repair guides for the Huawei P30 smartphone. Flagship smartphone from Huawei released March 2019, featuring a 6.1" OLED screen and an in-display fingerprint sensor.
79 Questions View all
My P30 wifi, Bluetooth, GPS are not working
Few months ago, I came back from work and its raining. My phone in my pocket is also wet and caused the camera lens to vaporized.
I have already open my phone and Clean it with Ultrasonic cleaner + 99% isopropyl alcohol.
My wifi works but in weak condition. My bluetooh and GPS also very weak.
Should i open all the metal plate on board to clean it? Or should i change the wifi, Bluetooth, gps ic. Can someone tell me which one is the related chip ic to change? Thanks.
1 Comment
And what if the wifi / Bluetooth turns of the after 2-3 seconds? Thanks
by
Add a comment
1 Answer
Most Helpful Answer
Hi,
Try using the phone’s WiFi as close as possible to the router to see if it works better.
If so then there is an antenna problem. The WiFi and the BT use the same antenna as they both work on the 2.4GHz band.
The phone will have to be opened and checked that the antenna has been reconnected properly.
Here’s an image taken from a teardown video of the phone that shows the antenna cable and connection in the phone.
(click on image to enlarge for better viewing)
Score 1
Add a comment
Add your answer
ahmad azraei will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 19
Past 30 Days: 77
All Time: 3,304
